Сабвуферы JL Audio
Легендарные сабвуферы американской компании JL Audio порадуют Вас фирменным незабываемо красивым, мягким и бархатистым басом!
Любителям низкого повседнева обязательно обратить внимание на топовую серию W7!
JL Audio 10W0v3
Оффтоп
Continuous Power Handling (RMS) 300 W
Recommended RMS Amplifier Power 75 - 300 W
Nominal Impedance (Znom) 4 Ω
Free Air Resonance (Fs) 32.09 Hz
Electrical “Q” (Qes) 0.64
Mechanical “Q” (Qms) 10.752
Total Speaker “Q” (Qts) 0.604
Equivalent Compliance (Vas) 1.095 cu ft / 31.01 L
One-Way Linear Excursion (Xmax)* 0.45 in / 11.4 mm
Reference Efficiency (no) 0.154%
Efficiency (1 W / 1 m)** 84.07 dB SPL
Effective Piston Area (Sd) 48.909 sq in / 0.0316 sq m
DC Resistance (Re) 4.280 Ω
ЦЕНА: руб.
JL Audio 12W0v3
Оффтоп
Free Air Resonance (Fs) 28.43 Hz
Electrical “Q” (Qes) 0.715
Mechanical “Q” (Qms) 10.709
Total Speaker “Q” (Qts) 0.67
Equivalent Compliance (Vas) 2.530 cu ft / 71.64 L
Reference Efficiency (no) 0.221%
Efficiency (1 W / 1 m)** 85.64 dB SPL
Effective Piston Area (Sd) 74.509 sq in / 0.0481 sq m
ЦЕНА: руб.
JL Audio 15W0v3
Оффтоп
Continuous Power Handling (RMS) 500 W
Recommended RMS Amplifier Power 150 - 500 W
Free Air Resonance (Fs) 24.43 Hz
Electrical “Q” (Qes) 0.508
Mechanical “Q” (Qms) 9.474
Total Speaker “Q” (Qts) 0.482
Equivalent Compliance (Vas) 5.106 cu ft / 144.60 L
One-Way Linear Excursion (Xmax)* 0.50 in / 12.7 mm
Reference Efficiency (no) 0.18%
Efficiency (1 W / 1 m)** 88.20 dB SPL
Effective Piston Area (Sd) 122.317 sq in / 0.0789 sq m
DC Resistance (Re) 3.555 Ω
ЦЕНА: руб.
JL Audio 8W1v2
Оффтоп
Continuous Power Handling (RMS) 150 W
Recommended RMS Amplifier Power 50 - 150 W
Free Air Resonance (Fs) 34.55 Hz
Mechanical “Q” (Qms) 6.26
Total Speaker “Q” (Qts) 0.47
Equivalent Compliance (Vas) 0.66 cu ft / 18.801 L
One-Way Linear Excursion (Xmax)* 0.3 in / 8 mm
Reference Efficiency (no) 0.149%
Efficiency (1 W / 1 m)** 83.86 dB SPL
Effective Piston Area (Sd) 32.67 sq in / 0.0211 sq m
DC Resistance (Re) 4.00 Ω
ЦЕНА: руб.
JL Audio 10W1v2
Оффтоп
Nominal Impedance (Znom) 4 Ω (Возможен вариант 8Ohm)
Free Air Resonance (Fs) 25.24 Hz
Electrical “Q” (Qes) 0.432
Mechanical “Q” (Qms) 6.336
Total Speaker “Q” (Qts) 0.405
Equivalent Compliance (Vas) 1.783 cu ft / 50.46 L
One-Way Linear Excursion (Xmax)* 0.375 in / 10 mm
Efficiency (1 W / 1 m)** 84.53 dB SPL
Effective Piston Area (Sd) 53.522 sq in / 0.0345 sq m
DC Resistance (Re) 4.086 Ω
ЦЕНА: руб.
JL Audio 12W1v2
Оффтоп
Free Air Resonance (Fs) 23.68 Hz
Electrical “Q” (Qes) 0.443
Mechanical “Q” (Qms) 6.465
Total Speaker “Q” (Qts) 0.414
Equivalent Compliance (Vas) 3.739 cu ft / 105.81 L
Reference Efficiency (no) 0.304%
Efficiency (1 W / 1 m)** 86.81 dB SPL
Effective Piston Area (Sd) 81.392 sq in / 0.0525 sq m
DC Resistance (Re) 4.101 Ω
ЦЕНА: руб.
JL Audio 13W1v2
Оффтоп
Continuous Power Handling (RMS) 350 W
Recommended RMS Amplifier Power 75 - 350 W
Free Air Resonance (Fs) 20.9 Hz
Electrical “Q” (Qes) 0.406
Mechanical “Q” (Qms) 6.936
Total Speaker “Q” (Qts) 0.384
Equivalent Compliance (Vas) 6.131 cu ft / 173.51 L
One-Way Linear Excursion (Xmax)* 0.475 in / 12 mm
Reference Efficiency (no) 0.375%
Efficiency (1 W / 1 m)** 87.71 dB SPL
Effective Piston Area (Sd) 105.774 sq in / 0.0682 sq m
DC Resistance (Re) 4.114 Ω
ЦЕНА: руб.
JL Audio 6W3v3
Оффтоп
Nominal Impedance (Znom) 4 Ω (возможен вариант 8Ohm)
Free Air Resonance (Fs) 41.80 Hz
Electrical “Q” (Qes) 0.533
Mechanical “Q” (Qms) 11.027
Total Speaker “Q” (Qts) 0.508
Equivalent Compliance (Vas) 0.181 cu ft / 5.13 L
One-Way Linear Excursion (Xmax)* 0.35 in / 8.89 mm
Reference Efficiency (no) 0.067%
Efficiency (1 W / 1 m)** 80.49 dB SPL
Effective Piston Area (Sd) 17.36 sq in / 0.0112 sq m
DC Resistance (Re) 3.476 Ω
ЦЕНА: руб.
JL Audio 8W3v3
Оффтоп
Continuous Power Handling (RMS) 250 W
Recommended RMS Amplifier Power 75- 250 W
Free Air Resonance (Fs) 35.14 Hz
Electrical “Q” (Qes) 0.501
Mechanical “Q” (Qms) 7.071
Total Speaker “Q” (Qts) 0.467
Equivalent Compliance (Vas) 0.54 cu ft / 15.29 L
One-Way Linear Excursion (Xmax)* 0.375 in / 10.0 mm
Reference Efficiency (no) 0.127%
Efficiency (1 W / 1 m)** 83.24 dB SPL
Effective Piston Area (Sd) 32.02 sq in / 0.021 sq m
DC Resistance (Re) 3.77 Ω
ЦЕНА: руб.
JL Audio 10W3v3
Оффтоп
Recommended RMS Amplifier Power 150- 500 W
Nominal Impedance (Znom) 2 Ω (возможен вариант 4Ohm)
Free Air Resonance (Fs) 32.97 Hz
Mechanical “Q” (Qms) 7.027
Total Speaker “Q” (Qts) 0.495
Equivalent Compliance (Vas) 1.136 cu ft / 32.17 L
One-Way Linear Excursion (Xmax)* 0.550 in / 14.0 mm
Reference Efficiency (no) 0.208%
Efficiency (1 W / 1 m)** 85.37 dB SPL
Effective Piston Area (Sd) 53.475 sq in / 0.0345 sq m
DC Resistance (Re) 1.70 Ω
ЦЕНА: руб.
JL Audio 12W3v3
Оффтоп
Free Air Resonance (Fs) 27.97 Hz
Electrical “Q” (Qes) 0.534
Mechanical “Q” (Qms) 7.678
Equivalent Compliance (Vas) 2.806 cu ft / 79.47 L
One-Way Linear Excursion (Xmax)* 0.510 in / 13.0 mm
Reference Efficiency (no) 0.313%
Efficiency (1 W / 1 m)** 87.15 dB SPL
Effective Piston Area (Sd) 80.600 sq in / 0.0520 sq m
DC Resistance (Re) 1.658 Ω
ЦЕНА: руб.
JL Audio 13W3v3
Оффтоп
Continuous Power Handling (RMS) 600 W
Recommended RMS Amplifier Power 150 - 600 W
Free Air Resonance (Fs) 24.70 Hz
Electrical “Q” (Qes) 0.544
Total Speaker “Q” (Qts) 0.504
Equivalent Compliance (Vas) 4.635 cu ft / 131.26 L
One-Way Linear Excursion (Xmax)* 0.610 in / 15.5 mm
Reference Efficiency (no) 0.349%
Efficiency (1 W / 1 m)** 87.63 dB SPL
Effective Piston Area (Sd) 103.850 sq in / 0.0670 sq m
DC Resistance (Re) 1.659 Ω
ЦЕНА: руб.
JL Audio 10W6v2
Оффтоп
Recommended RMS Amplifier Power 200 - 600 W
Nominal Impedance (Znom) Dual 4 Ω
Free Air Resonance (Fs) 28.5 Hz
Electrical “Q” (Qes) 0.497
Mechanical “Q” (Qms) 8.458
Total Speaker “Q” (Qts) 0.469
Equivalent Compliance (Vas) 1.18 cu ft / 33.4 L
One-Way Linear Excursion (Xmax)* 0.60 in / 15 mm
Efficiency (1 W / 1 m)** 83.7 dB SPL
Effective Piston Area (Sd) 51.4 sq in / 0.0332 sq m
DC Resistance (Re)*** 6.3 Ω
ЦЕНА: руб.
JL Audio 12W6v2
Оффтоп
Free Air Resonance (Fs) 25.0 Hz
Electrical “Q” (Qes) 0.48
Mechanical “Q” (Qms) 7.1
Total Speaker “Q” (Qts) 0.45
Equivalent Compliance (Vas) 2.82 cu ft / 79.9 L
One-Way Linear Excursion (Xmax)* 0.65 in / 17 mm
Reference Efficiency (no) 0.25%
Efficiency (1 W / 1 m)** 85.9 dB SPL
Effective Piston Area (Sd) 77.8 sq in / 0.0502 sq m
DC Resistance (Re)*** 6.75 Ω
ЦЕНА: руб.
JL Audio 13W6v2
Оффтоп
Continuous Power Handling (RMS) 750 W
Recommended RMS Amplifier Power 250 - 750 W
Free Air Resonance (Fs) 24.3 Hz
Electrical “Q” (Qes) 0.464
Mechanical “Q” (Qms) 6.7
Total Speaker “Q” (Qts) 0.434
Equivalent Compliance (Vas) 3.94 cu ft / 111.6 L
One-Way Linear Excursion (Xmax)* 0.85 in / 22 mm
Reference Efficiency (no) 0.331%
Efficiency (1 W / 1 m)** 87.4 dB SPL
Effective Piston Area (Sd) 100.4 sq in / 0.0648 sq m
DC Resistance (Re)*** 6.5 Ω
ЦЕНА: руб.
JL Audio 8W7AE-3
Оффтоп
Recommended RMS Amplifier Power 200 - 500 W
Nominal Impedance (Znom) 3 Ω
Free Air Resonance (Fs) 35.2 Hz
Electrical “Q” (Qes) 0.654
Mechanical “Q” (Qms) 9.5
Total Speaker “Q” (Qts) 0.612
Equivalent Compliance (Vas) 0.61 cu ft / 17.4 L
One-Way Linear Excursion (Xmax)* 0.75 in / 19 mm
Reference Efficiency (no) 0.112%
Efficiency (1 W / 1 m)** 82.7 dB SPL
Effective Piston Area (Sd) 38 sq in / 0.0245 sq m
DC Resistance (Re) 2.78 Ω
ЦЕНА: руб.
JL Audio 10W7AE-3
Оффтоп
Recommended RMS Amplifier Power 300 - 750 W
Free Air Resonance (Fs) 30.6 Hz
Electrical “Q” (Qes) 0.578
Mechanical “Q” (Qms) 7.647
Total Speaker “Q” (Qts) 0.537
Equivalent Compliance (Vas) 1.28 cu ft / 36.1 L
One-Way Linear Excursion (Xmax)* 0.9 in / 23 mm
Reference Efficiency (no) 0.171%
Efficiency (1 W / 1 m)** 84.3 dB SPL
Effective Piston Area (Sd) 59.8 sq in / 0.0386 sq m
DC Resistance (Re) 2.75 Ω
ЦЕНА: руб.
JL Audio 12W7AE-3
Оффтоп
Continuous Power Handling (RMS) 1000 W
Recommended RMS Amplifier Power 400 - 1000 W
Free Air Resonance (Fs) 27.2 Hz
Electrical “Q” (Qes) 0.514
Mechanical “Q” (Qms) 7.807
Equivalent Compliance (Vas) 2.33 cu ft / 66.0 L
One-Way Linear Excursion (Xmax)* 1.15 in / 29 mm
Reference Efficiency (no) 0.249%
Efficiency (1 W / 1 m)** 86.2 dB SPL
Effective Piston Area (Sd) 84 sq in / 0.0542 sq m
DC Resistance (Re) 2.47 Ω
ЦЕНА: руб.
JL Audio 13W7AE-3
Оффтоп
Continuous Power Handling (RMS) 1500 W
Recommended RMS Amplifier Power 500 - 1500 W
Nominal Impedance (Znom) Dual 1.5 Ω
Free Air Resonance (Fs) 23.5 Hz
Electrical “Q” (Qes) 0.476
Mechanical “Q” (Qms) 7.517
Total Speaker “Q” (Qts) 0.448
Equivalent Compliance (Vas) 3.68 cu ft / 104.3 L
One-Way Linear Excursion (Xmax)* 1.25 in / 32 mm
Reference Efficiency (no) 0.269%
Efficiency (1 W / 1 m)** 86.3 dB SPL
Effective Piston Area (Sd) 107.35 sq in / 0.0693 sq m
DC Resistance (Re)*** 2.41 Ω
ЦЕНА: руб.
По вопросам цены, приобретения и заказов обращаться в личку!
Изменено пользователем heyford
Меломан ля-ля...
