Наличие сабов Fi Car Audio & Ascendant Audio в Москве
Skillz
Выбирайте чо по-кайфу :hi:
Fi Car Audio
Ib3 18 d2 - 1шт
18" - 16000р - параметры Оффтоп
IB3 Series: 12”, 15”, and 18”
Single 2 and Single 4 Ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3” diameter 2 or 4 layer coil
Large single magnet
Single progressive spider
IB318
SINGLE 2 | SINGLE 4
Fs: 22.3 Hz | 22.5 Hz
Re: 1.5 Ohms/coil | 2.8 Ohms/coil
Qms: 3.33 | 3.41
Qes: ..81 | .77
Qts: .65 | .62
Mms: 272g | 270g
Sd: 1210cm^2 | 1210cm^2
Vas: 381 l | 381 l
Spl: 89.1dB 1W/1m | 89.4dB 1W/1m
Bl: 8.43 N/A | 11.8 N/A
Xmax: 30mm
Rms: 550W @ 20Hz
Sealed box: Infinite Baffle Only
Ported box: N/A
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.500”
Displacement: 0.22cuft
Ssd12 d2 - 3шт
12" - 15000р - параметры - Оффтоп
SSD Series: 10”, 12”, 15”, and 18”
Dual 1 and Dual 2 Ohm
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
3” diameter 4 layer coil
Single high grade magnet
Triple progressive spiders
Optional Heli-cool system
SSD12
DUAL 1 | DUAL 2
Fs: 30.1 Hz | 30.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 7.65 | 7.65
Qes: .37 | .37
Qts: .36 | .36
Mms: 248g | 248g
Cms: 0.11mm/N | 0.11mm/N
Sd: 480cm^2 | 480cm^2
Vas: 36.5 l | 36.5 l
Spl: 86.1dB 1W/1m | 86.1dB 1W/1m
Bl: 13.1 N/A | 18.7 N/A
Xmax: 20mm
Rms: 1000W
Sealed box: .7-1.2 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.500”
Displacement: 0.14cuft
Ssd15 d2 red - 1шт
15" - 16000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
SSD15
DUAL 1 | DUAL 2
Fs: 29.6 Hz | 29.6 Hz
Qms: 8.73 | 8.73
Qes: .43 | .43
Qts: .41 | .41
Mms: 288g | 288g
Cms: 0.10mm/N | 0.10mm/N
Sd: 810cm^2 | 810cm^2
Vas: 93.0 l | 93.0 l
Spl: 89.3dB 1W/1m | 89.3dB 1W/1m
Xmax: 20mm
Rms: 1000W
Sealed box: 1.5-2.5 cuft
Ported box: 3-4 cuft @ 33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.000”
Displacement: 0.17cuft
Ssd18 d1 - 1шт
18" - 18500р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
SSD18
DUAL 1 | DUAL 2
Fs: 27.6 Hz | 27.6 Hz
Qms: 9.56 | 9.56
Qes: .47 | .47
Qts: .45 | .45
Mms:338g | 338g
Cms: 0.098mm/N | 0.098mm/N
Vas: 201.4 l | 201.4 l
Spl: 91.4dB 1W/1m | 91.4dB 1W/1m
Xmax: 20mm
Rms: 1000W
Sealed box: 3.5-5 cuft
Ported box: 6-10 cuft @ 33Hz
Sub OD: 18.500”
Cut ID: 16.750”
Q10 d2 - 1шт
10" - 18000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
3" diameter 4 layer coil
Quad progressive spiders
High or low Qts motors
And many other custom options
Q10
DUAL 1 | DUAL 2
Fs: 34.1 Hz | 34.0 Hz
Re: 0.70 Ohms/coil | 1.4 Ohms/coil
Qms: 7.31 | 7.38
Qes: .37 | .37
Qts: .36 | .36
Mms: 230g | 2235g
Cms: .88mm/N | .88mm/N
Sd: 310cm^2 | 310cm^2
Vas: 11.8 l | 11.8 l
Spl: 83.3dB 1W/1m | 83.2dB 1W/1m
Bl: 13.9 N/A | 19.6 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: .2-.5 cuft HQTS
Ported box: .5-1.2 cuft @ 28-33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Displacement: 0.12cuft
Q15 d2 blue - 1шт
15" - 20000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Q15
DUAL 1 | DUAL 2
Fs: 32.4 Hz | 32.1 Hz
Qms: 8.52 | 8.61
Qes: .43 | .44
Qts: .41 | .42
Mms: 293g | 299g
Cms: 0.82mm/N | 0.82mm/N
Vas: 75.6 l | 75.6 l
Spl: 89.6dB 1W/1m | 89.4dB 1W/1m
Bl: 13.9 N/A | 19.65 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
BTL n3 12 d1 - 1шт
BTL n3 12 d2 - 2шт
12" - 48000р - параметры - Оффтоп
BTL Series: 12”, 15”, and 18”
Dual 1 and Dual 2 Ohm (custom options available)
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
High Flux density design
3” diameter 8 layer coil (High Xmax coil option)
Triple Neodymium high flux magnets
5-7 progressive spiders packs
Tri-flow integrated heatsink
N312
DUAL 1 | DUAL 2
Fs: 56.3 Hz | 55.3 Hz
Qms: 7.45 | 7.69
Qes: .26 | .25
Qts: .25 | .24
Mms: 214g | 222g
Vas: 12.1 l | 12.1 l
Spl: 91.1dB 1W/1m | 90.8dB 1W/1m
Bl: 20.2 N/A | 28.8 N/A
Xmax: 28mm | 28mm
Rms: 3000W | 3000W
Sealed box: N/A cuft | N/A cuft
Ported box: 1.5-2.5cuft | 1.5-2.5cuft
Sub OD: 12.500” | 12.500”
Cut ID: 11.125” | 11.125”
Mounting depth: 7.250” | 7.250”
Displacement: 0.18cuft | 0.18cuft
BTL n3 15 d1 - 3шт
15" - 49000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
N315
DUAL 1 | DUAL 2
Fs: 54.5 Hz | 54.4 Hz
Qms: 9.19 | 9.28
Qes: .32 | .32
Qts: .31 | .31
Mms: 274g | 280g
Vas: 28.95 l | 28.95 l
Spl: 93.4dB 1W/1m | 93.3dB 1W/1m
Xmax: 28mm | 28mm
Rms: 3000W | 3000W
Ported box: 2.5-5cuft | 2.5-5cuft
Sub OD: 15.625” | 15.625”
Cut ID: 14.125” | 14.125”
Mounting depth: 8.750” | 8.750”
Displacement: 0.21cuft | 0.21cuft
BTL n3 18 d1 - 2шт
BTL n3 18 d2 - 2шт
18" - 52000р - параметры - Оффтоп
Cast basket
Wrap around gasket
Push terminals
16 integrated leads
FEA optimized motor
N318
DUAL 1 | DUAL 2
Fs: 51.1 Hz | 50.4 Hz
Qms: 10.1 | 10.26
Qes: .36 | .35
Qts: .35 | .34
Mms: 320g | 329g
Vas: 62.1 l | 62.1 l
Spl: 95.3dB 1W/1m | 95.4dB 1W/1m
Xmax: 28mm | 28mm
Rms: 3000W | 3000W
Ported box: 4-10cuft | 4-10cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 10.250” | 10.250”
Displacement: 0.26cuft | 0.26cuft
Sp4 15 d1 - 3шт
Sp4 15 d2 - 4шт
15" - 37500р - параметры - Оффтоп
SP4 Series: Currently in 15” and 18”
Extra heavy aluminum basket
Wrap around gasket
Push terminals
144 tinsel count leads
FEA optimized motor
4” diameter 4 layer coil (Flatwind standard)
Double stack magnets
Five progressive 10" spiders
Optional Heli-cool systerm
Machined in house at Fi
SP415
DUAL 1 | DUAL 2
Fs: 27.6 Hz | 27.9 Hz
Re: 0.65 Ohms/coil | 1.27 Ohms/coil
Qms: 6.56 | 6.45
Qes: .52 | .52
Qts: .48 | .48
Mms: 434g | 424g
Cms: 0.77mm/N | 0.77mm/N
Vas: 70.4 l | 70.4 l
Spl: 86.4dB 1W/1m | 86.5dB 1W/1m
Bl: 13.7 N/A | 19.1 N/A
Xmax: 33mm | 33mm
Rms: 2500W | 2500W
Sealed box: 2-3.5cuft | 2-3.5 cuft
Ported box: 3-5cuft | 3-5cuft
Mounting depth: 11.250” | 11.250”
Sp4 18 d2 - 2шт
18" - 39000р - параметры - Оффтоп
Wrap around gasket
Push terminals
FEA optimized motor
SP418
DUAL 1 | DUAL 2
Fs: 24.7 Hz | 24.9 Hz
Qms: 7.45 | 7.38
Qes: .60 | .59
Qts: .55 | .55
Mms: 555g | 544g
Cms: 0.74mm/N | 0.74mm/N
Vas: 153.7 l | 153.7 l
Spl: 87.8dB 1W/1m | 87.9dB 1W/1m
Xmax: 33mm | 33mm
Rms: 2500W | 2500W
Sealed box: 4-6 cuft | 4-6 cuft
Ported box: 6-8cuft | 6-8cuft
Mounting depth:11.750” | 11.750”
Ascendant Audio
Arsenal 12 d4 - 5шт
Arsenal 15 d4 - 1щт
Chaos 10d2 - 1шт
Havoc12 d1 - 1шт
Havoc12 d2 - 1шт
Havoc 15 d1 - 3шт
Havoc 18 d1 - 1шт
Havoc 18 d2 - 2шт
Mayhem 12 d1 - 3шт
Mayhem15 d2 - 2шт
Mayhem 18 d2 - 2шт
Mayhem 18 d1 - 1шт
Изменено пользователем Skillz
да, неплохо бы было ценник возле каждой позиции написать, чтобы люди не лазали из темы в тему :blush:
BTL n3 15 d1' date=' Sp4 15 d1 можно цену узнать?[/quote']
вот скорее всего http://www.bassclub.ru/forum/showthread.php?t=33834
Все цены - розница как указанно в соответствующих темах. Но есть спец предложениях
На сабы Ascendant Audio
2 штуки - AA Havoc 18" - 49000р
2 штуки - AA Havoc d1 15" - 44000р
2 штук АА Aresenal 15d4 + Sundown Audio SAZ1500v3 - 45000р
Только до выходных
При покупке Fi BTL n3 - ценный подарок!
Подправил с ценами и описанием. Если вечером не сдамся, то и по АА тоже сделаю
по наличию инфа акутальна?
На 90% да. Лучше спросить конкретно что интересует, я уточню
две 12хи майхем есть за хорошую цену - д1
