Предусилитель XLR USB Centrance MicPort Pro
alz
В другом моём объявлении отличный измерительный микрофон Behringer ECM800 к этому предусилителю.
The Original: Often Imitated, Never Duplicated, 24/96 USB Preamp!
The CEntrance MicPort Pro is the easiest way to capture a professional-quality vocal take, communicate with clarity over Skype or record studio-grade instrument samples.
Much more than a simple XLR to USB adapter, the MicPort Pro is the only portable mic preamp with a built-in, 24bit/96kHz, broadcast-quality A/D converter - a CEntrance exclusive. It captures the cleanest signal, making it an ideal choice for professional recordings. The built-in loud headphone amp and studio-grade knobs make it both useful and convenient on the road.
MicPort Pro is used by the BBC, CNN, NBC, CBS, ABC, NPR, Harpo Studios, Warner Brothers, and professional musicians and voiceover artists worldwide. MicPort Pro is instantly compatible with Windows XP/Vista/7, Mac OS X 10.4 and above, and Linux.
No batteries. No latency. No headaches. Just plug in and record.
Features
Lowest-noise mic preamp with 24-bit/96kHz A/D converter for extra clarity in recordings
103.5dB dynamic range, perfect complement to high-end condenser and ribbon mics
48V phantom power — compatible with all professional mics
Loud headphone amp for zero latency monitoring - works with any headphones
Studio-grade control knobs for Preamp Gain and Headphone Volume
Stereo capability — record in stereo with twoMicPort Pro/AxePort Pro units (Mac & PC)
Stylish and sturdy aluminum body that's only 4.5 inches (11.5 cm) long
Applications
MicPort Pro is powered from the USB port and needs no batteries. Aside from recording music and vocals, it is perfect for Skype users requiring extra clarity in communications, Test & Measurement applications demanding flat frequency responce, and anywhere else where portability, studio quality and ease of use are required features. Here are some typical applications:
Voice Over and Narration
Broadcast newsgathering (ENG)
Vocal and instrument recording and overdubs
High-intelligibility Skype communications
Video production for Corporate Clients and Youtube
Acoustical Test and Measurement
Device Aggregation
A CEntrance exclusive! The included Windows control panel adds a valuable feature to the MicPort Pro. Now you can use more than one unit on the same PC to make stereo or multichannel recordings. CEntrance Universal Driver software control panel combines multiple MicPort Pro or AxePort Pro units into a single multichannel device, perfect for using ASIO applications like Cubase, Nuendo, Cakewalk and many others.
